FreeRTOS_SetNetmask()
FreeRTOS_IP.h
1void FreeRTOS_SetNetmask( uint32_t ulNetmask );
This function can be used to update the IPv4 subnet mask used by the FreeRTOS-Plus-TCP device after the TCP stack has already been initialized with a call to FreeRTOS_IPInit().
ulNetmask
The 32-bit IPv4 netmask, in network endian order, which the device should use. FreeRTOS_htonl
can be used to get the network endian representation of the 32-bit IP netmask.
Caution:
This function is not thread safe and should be used with the
taskENTER_CRITICAL/taskEXIT_CRITICAL
See the FreeRTOS_SetIPAddress page for an example.
