xSemaphoreCreateBinary
[Semaphores]
TIP: In many usage scenarios it is faster and more memory efficient to use a direct to task notification instead of a binary semaphore
semphr. h
1SemaphoreHandle_t xSemaphoreCreateBinary( void );
Creates a binary semaphore, and returns a handle by which the semaphore can be referenced. configSUPPORT_DYNAMIC_ALLOCATION must be set to 1 in FreeRTOSConfig.h, or left undefined (in which case it will default to 1), for this RTOS API function to be available.
Return values:
  • NULL
    The semaphore could not be created because there was insufficient FreeRTOS heap available.
  • Any other value
    The semaphore was created successfully. The returned value is a handle by which the semaphore can be referenced.
1SemaphoreHandle_t xSemaphore;
2
3void vATask( void * pvParameters )
4{
5 /* Attempt to create a semaphore. */
6 xSemaphore = xSemaphoreCreateBinary();
7
8 if( xSemaphore == NULL )
9 {
10 /* There was insufficient FreeRTOS heap available for the semaphore to
11 be created successfully. */
12 }
13 else
14 {
15 /* The semaphore can now be used. Its handle is stored in the
16 xSemahore variable. Calling xSemaphoreTake() on the semaphore here
17 will fail until the semaphore has first been given. */
18 }
19}
