xStreamBufferResetFromISR()
[RTOS Stream Buffer API]
stream_buffer.h
1BaseType_t xStreamBufferResetFromISR( StreamBufferHandle_t xStreamBuffer );
An interrupt safe version of the xStreamBufferReset() API function.
Resets a stream buffer to its initial, empty, state. Any data that was in the stream buffer is discarded. A stream buffer can only be reset if there are no tasks blocked waiting to either send to or receive from the stream buffer.
Use
to reset a stream buffer from a task. Use
to reset a stream buffer from an interrupt service routine (ISR).
  • xStreamBuffer
    The handle of the stream buffer to reset.
  • If the stream buffer is reset then pdPASS is returned.
  • If there was a task blocked waiting to send to or read from the stream buffer then the stream buffer will not be reset and pdFAIL is returned.
