xSemaphoreCreateRecursiveMutexStatic
[Semaphores]
semphr. h
SemaphoreHandle_t xSemaphoreCreateRecursiveMutexStatic(
                              StaticSemaphore_t *pxMutexBuffer )
Creates a recursive mutex, and returns a handle by which the mutex can be referenced. Recursive mutexes cannot be used in interrupt service routines. configUSE_RECURSIVE_MUTEXES and configSUPPORT_STATIC_ALLOCATION must both be set to 1 in FreeRTOSConfig.h for xSemaphoreCreateRecursiveMutexStatic() to be available.
Like non-recursive mutexes, recursive mutexes implement a priority inheritance algorithm. The priority of a task that 'takes' a mutex will be temporarily raised if another task of higher priority attempts to obtain the same mutex. The task that owns the mutex 'inherits' the priority of the task attempting to 'take' the same mutex. This means the mutex must always be 'given' back - otherwise the higher priority task will never be able to obtain the mutex, and the lower priority task will never 'disinherit' the priority. For more on the priority inheritance mechanism see the FreeRTOS Mutex documentation page.
pxMutexBuffer   Must point to a variable of type StaticSemaphore_t, which will be used to hold the mutex type semaphore's state.
Return:
If the recursive mutex was created successfully then a handle to the created mutex is returned. If the recursive mutex was not created because pxMutexBuffer was NULL then NULL is returned.
    /* Create a recursivemutex semaphore without using any dynamic
    memory allocation.  The mutex's data structures will be saved into
    the xMutexBuffer variable. */
    xSemaphore = xSemaphoreCreateRecursiveMutexStatic( &xMutexBuffer );
    handle will not be NULL. */
    configASSERT( xSemaphore );
