FreeRTOS Mutexes
FreeRTOS Mutexes
Mutexes are binary semaphores that include a priority inheritance mechanism. Whereas binary semaphores are the better choice for implementing synchronisation (between tasks or between tasks and an interrupt), mutexes are the better choice for implementing simple mutual exclusion (hence 'MUT'ual 'EX'clusion).
When used for mutual exclusion the mutex acts like a token that is used to guard a resource. When a task wishes to access the resource it must first obtain ('take') the token. When it has finished with the resource it must 'give' the token back - allowing other tasks the opportunity to access the same resource.
Mutexes use the same semaphore access API functions so also permit a block time to be specified. The block time indicates the maximum number of 'ticks' that a task should enter the Blocked state when attempting to 'take' a mutex if the mutex is not immediately available. Unlike binary semaphores however - mutexes employ priority inheritance. This means that if a high priority task blocks while attempting to obtain a mutex (token) that is currently held by a lower priority task, then the priority of the task holding the token is temporarily raised to that of the blocking task. This mechanism is designed to ensure the higher priority task is kept in the blocked state for the shortest time possible, and in so doing minimise the 'priority inversion' that has already occurred.
Priority inheritance does not cure priority inversion! It just minimises its effect in some situations. (See Simplified priority inheritance below.) Hard real time applications should be designed such that priority inversion does not happen in the first place.
Using a mutex to guard access to a shared resource.
FreeRTOS implements a basic priority inheritance mechanism which was designed to optimize both space and execution cycles. A full priority inheritance mechanism requires significantly more data and processor cycles to determine inherited priority at any moment, especially when a task holds more than one mutex at a time.
Keep in mind these specific behaviors of the priority inheritance mechanism:
  • A task can have its inherited priority raised further if it takes a mutex without first releasing mutexes it already holds.
  • A task remains at its highest inherited priority until it has released all the mutexes it holds. This is regardless of the order the mutexes are released.
  • A task will remain at the highest inherited priority if multiple mutexes are held regardless of tasks waiting on any of the held mutexes completing their wait (timing out).
