RTOS Task Notifications
Used As Light Weight Counting Semaphores
Related pages:
Unblocking an RTOS task with a direct notification is 45% faster and
uses less RAM than unblocking a task with a semaphore. This page
demonstrates how this is done.
A counting semaphore is a semaphore that can have a count value of zero up to
a maximum value set when the semaphore is created.
A task can only 'take' the semaphore if it is available, and the semaphore is only
available if its count is greater than zero.
When a task notification is used in place of a
counting semaphore the receiving task's
notification value is used in place of the
counting semaphore's count value, and the ulTaskNotifyTake() (or ulTaskNotifyTakeIndexed())
API function is used in place of the semaphore's xSemaphoreTake() API function.
The ulTaskNotifyTake() function's xClearOnExit parameter is set to pdFALSE so the
count value is only decremented (rather than cleared) each time the notification
is taken - emulating a counting semaphore.
Likewise the xTaskNotifyGive() (or xTaskNotifyGiveIndexed()) or
vTaskNotifyGiveFromISR() (or vTaskNotifyGiveIndexedFromISR()) functions are
used in place of the semaphore's xSemaphoreGive() and xSemaphoreGiveFromISR()
functions.
The first example below uses the receiving task's notification value as a counting
semaphore. The second example provides a more pragmatic and efficient implementation.
Example 1:
/* An interrupt handler that does not process interrupts directly,
but instead defers processing to a high priority RTOS task. The
ISR uses RTOS task notifications to both unblock the RTOS task
and increment the RTOS task's notification value. */
void vANInterruptHandler( void )
/* Clear the interrupt. */
prvClearInterruptSource();
/* xHigherPriorityTaskWoken must be initialised to pdFALSE.
If calling vTaskNotifyGiveFromISR() unblocks the handling
task, and the priority of the handling task is higher than
the priority of the currently running task, then
xHigherPriorityTaskWoken will be automatically set to pdTRUE. */
/* Unblock the handling task so the task can perform
any processing necessitated by the interrupt. xHandlingTask
is the task's handle, which was obtained when the task was
created. vTaskNotifyGiveFromISR() also increments
the receiving task's notification value. */
/* Force a context switch if xHigherPriorityTaskWoken is now
set to pdTRUE. The macro used to do this is dependent on
the port and may be called portEND_SWITCHING_ISR. */
/* A task that blocks waiting to be notified that the peripheral
needs servicing. */
void vHandlingTask( void *pvParameters )
BaseType_t xEvent;
const TickType_t xBlockTime = pdMS_TO_TICKS( 500 );
uint32_t ulNotifiedValue;
for( ;; )
/* Block to wait for a notification. Here the RTOS
task notification is being used as a counting semaphore.
The task's notification value is incremented each time
the ISR calls vTaskNotifyGiveFromISR(), and decremented
each time the RTOS task calls ulTaskNotifyTake() - so in
effect holds a count of the number of outstanding interrupts.
The first parameter is set to pdFALSE, so the notification
value is only decremented and not cleared to zero, and one
deferred interrupt event is processed at a time. See
example 2 below for a more pragmatic approach. */
ulNotifiedValue = ulTaskNotifyTake( pdFALSE,
xBlockTime );
if( ulNotifiedValue > 0 )
/* Perform any processing necessitated by the interrupt. */
xEvent = xQueryPeripheral();
if( xEvent != NO_MORE_EVENTS )
vProcessPeripheralEvent( xEvent );
/* Did not receive a notification within the expected
time. */
vCheckForErrorConditions();
Example 2:
This example shows a more pragmatic and efficient implementation for the
RTOS task. In this implementation the value returned from ulTaskNotifyTake() is
used to know how many outstanding ISR events must be processed, allowing the
RTOS task's notification count to be cleared back to zero each time ulTaskNotifyTake()
is called. The interrupt service routine (ISR) is assumed to be as demonstrated
in example 1 above.
to use. */
const UBaseType_t xArrayIndex = 0;
needs servicing. */
BaseType_t xEvent;
for( ;; )
/* As before, block to wait for a notification form the ISR.
This time however the first parameter is set to pdTRUE,
clearing the task's notification value to 0, meaning each
outstanding outstanding deferred interrupt event must be
processed before ulTaskNotifyTake() is called again. */
ulNotifiedValue = ulTaskNotifyTakeIndexed( xArrayIndex,
pdTRUE,
xBlockTime );
if( ulNotifiedValue == 0 )
time. */
/* ulNotifiedValue holds a count of the number of
outstanding interrupts. Process each in turn. */
while( ulNotifiedValue > 0 )
ulNotifiedValue--;
break;
